I was trying to understand differences between :: @( posedge Sig ) V/S $rose( Sig ) ::
(1) $rose( Sig ) checks that LSb of Sig changes from 0 / X / Z to 1 whereas
@( posedge Sig ) will be triggered whenever Sig changes from 0 / X / Z to 1 OR even **0 to X / Z** .
(2) $rose( Sig ) returns 1’b0 / 1’b1 and hence can be used as an argument to System function like $display / $sformatf
whereas @( posedge Sig ) can't be used as argument to System function like $display / $sformatf **as it doesn't return anything**
I have some confusion regarding the below 3rd difference as LRM’s wordings are a little confusing ::
(3)
LRM 9.4.2 :: An implicit event shall be detected on any change in the value of the expression. An edge event shall be detected only on the LSB of the expression. A change of value in any operand of the expression without a change in the result of the expression shall not be detected as an event.
So if 2-bit variable Sig changes from default value 2’bXX to 2’b1X , should @( posedge Sig ) be triggered ?
i.e Sig[1] changes from X to 1 whereas LSb remains at X .
logic [1:0] Sig ;
always @( posedge Sig ) $display(" TIME : %0t posedge @( Sig ) triggered " , $time) ;
#4 ; Sig = 2'b1X ; // TIME : 04 . Sig[1] Changes from X to 1 !!
#6 ; Sig = 2'b11 ; // TIME : 10
Any further differences I have missed out on ?
