When I use set_inst_override_by_type to override an old driver,but the simulation stop by because compile Error:
** Error: …/test/sv/tc_axi.sv(142): (vlog-2164) Class or package ‘axi_wr_driver’ not found.
** Error: …/test/sv/tc_axi.sv(142): near “::” syntax error, unexpected ::, expecting ’)’
** Error: …/test/sv/tc_axi.sv(142): (vlog-2164) Class or package ‘axi_wr_new_driver’ not found.
When you are getting compilation error it doesn’t mean that your set_type_override is not working.
From the log file error messages, it seems like you haven’t compile it properly OR maybe you didn’t import the package that you have the definition of axi_wr_driver and axi_wr_new_driver on the same code that you have your test’s class definition.
And additionally, from your code snippet it seems like your axi_wr_driver doesn’t use the uvm_component_utils to register the class into UVM factory. I hope that you may just have missed it when you add this query.
When you want to use UVM factory override, both of the original class and override class has to be registered in UVM Factory.
Both of axi_wr_driver and axi_wr_new_driver has been registered in UVM Factory,here no problem.
I added axi_wr_driver.sv & axi_wr_new_driver.sv in aix_pkg.sv.
From the compile Error, it seems that tc_axi_write cann’t recognized the two class: axi_wr_driver & axi_wr_new_driver, I don’t know where is the issue. If it need to add full path of axi_wr_driver
or u_wr_driver?
Okay. Will please check there is no typo or anything missing on the code snippet that you shared? It will be helpful if you share the code if possible.
Showing the exact code of line ./test/sv/tc_axi.sv(142) will be helpful as well.
I can see one issue on your code (based on the snippet above).
I can see that the axi_wr_driver is not parameterized with with any sequence item. And I suspect that following code is the one that has problem, because you are passing paramater to the axi_wr_driver.
class axi_wr_new_driver extends axi_wr_driver #(axi_wr_transfer);
I seems like you haven’t import axi_pkg::* under the module/package that you have tc_axi_write class. That is what I mentioned in my first response to your question.
Anyway, it is good to know that you managed to figure it out yourself.
No problem:D.
I see, you may not have it imported under your package axi_test_pkg; then.
The point is you should import package where you defined the class that you want to use in other SystemVerilog’s scope (package/module/interface/program). You can choose either to import the entire package
Unlike module/interface/program, package is a standalone scope and it will not be instantiated under your testbench or any module/interface/program instances hierarchy. Calling the import is actually means something like that you are just getting the visibility of a package’s content from your current scope (module/interface/program/package). When you import a package into a package, it doesn’t mean that the package being imported will be included into the parent package and everything inside it will become a content of parent package. See description below on how it is described in SystemVerilog LRM page 739.
26.2 Package declarations
SystemVerilog packages provide an additional mechanism for sharing parameters, data, type, task, function,
sequence, property, and checker declarations among multiple SystemVerilog modules, interfaces, programs,
and checkers.
Packages are explicitly named scopes appearing at the outermost level of the source text (at the same level as
top-level modules and primitives). Types, nets, variables, tasks, functions, sequences, properties, and
checkers may be declared within a package. Such declarations may be referenced within modules,
interfaces, programs, checkers, and other packages by either import or fully resolved name.
Packages may contain processes inside checkers only. Therefore, net declarations with implicit continuous
assignments are not allowed.
I recommend you to go through the SystemVerilog LRM to understand better on this, as I may be able to ONLY answer your direct question.
