class master_drv extends uvm_driver #(master_txn);
`uvm_component_utils(master_drv)
master_agt_config m_cfgh;
virtual uart_inf vif;
master_txn xtnh;
logic [31:0] divisor;
time clk_prd;
real clk_frq;
reg [31:0] cnt;
time clk_rise_edge ;
logic bclk;
//////////////////new_constructor//////////////////////////////
function new(string name="master_drv",uvm_component parent);
super.new(name,parent);
/////////////////////////////build_phase//////////////////////////////
virtual function void buid_phase(uvm_phase phase);
super.build_phase(phase);
if(!uvm_config_db#(master_agt_config)::get(this,"","master_agt_config",m_cfgh))
`uvm_fatal("MASTER","cannot get the master config from config_db");
xtnh=master_txn::type_id::create("xtnh");
////////////////////////////connect_phase/////////////////////////
virtual function void connect_phase(uvm_phase phase);
super.connect_phase(phase);
vif=m_cfgh.vif;
////////////////////run_phase/////////////////////////////
@(posedge vif.g_clk)
vif.g_rst<=0;
vif.g_rst<=1;
forever
uart_bclk(req);
seq_item_port.item_done();
task uart_bclk(master_txn xtnh);
forever
clk_rise_edge = $time;
$display( "time = %t ; clk_rise_edge = %t",$time, clk_rise_edge);
@(posedge vif.g_clk) begin
clk_prd = $time - clk_rise_edge;
clk_frq = 1e9 / (clk_prd );
$display( "frequency = %g ",clk_frq);
divisor = clk_frq / (xtnh.baud_rate);
$display( "divisor= %d ",divisor);
@ (posedge vif.g_clk or posedge vif.g_rst)
if(vif.g_rst) begin
cnt <= 32'd0;
bclk <= 1'b0;
else if(cnt >= divisor) begin
bclk <= 1'b1;
cnt <= 32'd0;
else begin
cnt <= cnt + 1'b1;
bclk<= 1'b0;
Error-[NOA] Null object access
master_drv.sv, 38
The object at dereference depth 1 is being used before it was
constructed/allocated.
Please make sure that the object is allocated before using it.
line no 38 : vif = mcfgh.vif;
even though i have constructed config am getting null object access.
may i know what is wrong with the code
