I am getting this error during this simulation in scoreboard
//ALU_SCOREBOARD
import uvm_pkg::*;
`include "uvm_macros.svh"
class alu_scoreboard extends uvm_scoreboard;
//Factory registration
`uvm_component_utils(alu_scoreboard)
//Define analysis port
uvm_analysis_imp #(data_packet, alu_scoreboard) dp_imp;
uvm_tlm_analysis_fifo #(data_packet) inp_fifo;
uvm_tlm_analysis_fifo #(data_packet) mon_fifo;
//Create sequence item
data_packet dp;
//Construct function new
super.new(name, parent);
//Build phase
dp_imp = new("dp_imp", this);
dp = data_packet::type_id::create("dp", this);
endfunction: build_phase
logic [2:0] dout;
logic flag_1;
task write_fifo(data_packet dp1);
`uvm_info("input_data", "expected data prediction", UVM_LOW)
if(!dp1.resetn)begin
dout <= 0;
flag_1 <= 0;
else if(dp1.inp_en) begin
if(dp1.opcode) begin
dout <= dp1.a + dp1.b;
flag_1 <= 1;
else begin
dout <= dp1.a - dp1.b;
flag_1 <= 1;
else begin
dout <= 0;
flag_1 <= 0;
if(!dp.resetn) begin
dp1.outp <= 0;
dp1.valid_out <= 0;
else if (flag_1 == 1) begin
dp1.outp <= dout;
dp1.valid_out <= 1;
flag_1 <= 0;
// void'(inp_fifo.try_put(dp1));
// `uvm_info("input_data", "data sent into fifo", UVM_LOW)
else begin
dp1.outp <= 0;
dp1.valid_out <= 0;
join
endtask: write_fifo
function void write(data_packet dp2);
`uvm_info("actal_data", "actual data", UVM_LOW)
void'(mon_fifo.try_put(dp2));
endfunction: write
//Run phase
forever begin
//fork
data_packet exp, act;
write_fifo(dp);
join
`uvm_info("scoreboard run task", "expected data", UVM_LOW)
inp_fifo.get(exp); //error is shown at this line number
`uvm_info("scoreboard run task", "actual data", UVM_LOW)
mon_fifo.get(act);
if(act.compare(exp))
`uvm_info("scoreboard run task", "Test PASS", UVM_LOW)
`uvm_info("scoreboard run task", "Test FAIL", UVM_LOW)
//join
endclass : alu_scoreboard
