Hello, i am building a parametrizable UVC and i am getting this error in the top environment of the UVC.
This is the beginning of the environment:
class ds_env#(int PARALLEL_CORE_WIDTH=40) extends uvm_env;
`uvm_component_param_utils(ds_env#(PARALLEL_CORE_WIDTH))
// Environment Configuration Parameters
ds_config cfg; // environment configuration object
// Components of the environment
ds_agent#(PARALLEL_CORE_WIDTH) h_ds_agents;//THE ERROR IS IN THIS LINE OR IN THE NEXT IF I COMMENT THIS ONE OUT
ds_scoreboard#(PARALLEL_CORE_WIDTH) tx_scoreboards;
ds_scoreboard#(PARALLEL_CORE_WIDTH) rx_scoreboards;
ds_scoreboard#(PARALLEL_CORE_WIDTH) loopback_scoreboards;
The beginning of the ds_agent class is as follow:
class ds_agent#(int PARALLEL_CORE_WIDTH=40) extends uvm_agent;
`uvm_component_param_utils(ds_agent#(PARALLEL_CORE_WIDTH))
// Components of the agent
ds_tx_agent#(PARALLEL_CORE_WIDTH) tx_active_agents;
ds_tx_agent#(PARALLEL_CORE_WIDTH) tx_passive_agents;
ds_rx_agent#(PARALLEL_CORE_WIDTH) rx_active_agents;
ds_rx_agent#(PARALLEL_CORE_WIDTH) rx_passive_agents;
uvm_analysis_port #(ds_seq_item#(PARALLEL_CORE_WIDTH)) h_trans_item_collected_ap[4];
And the beginning of the scoreboard is this:
class ds_scoreboard#(int PARALLEL_CORE_WIDTH=40) extends uvm_scoreboard;
`uvm_component_param_utils(ds_scoreboard#(PARALLEL_CORE_WIDTH))
uvm_analysis_imp_decl(_input_port) uvm_analysis_imp_input_port#(ds_seq_item#(PARALLEL_CORE_WIDTH),ds_scoreboard#(PARALLEL_CORE_WIDTH)) in_trans_imp; uvm_analysis_imp_decl(_output_port)
uvm_analysis_imp_output_port#(ds_seq_item#(PARALLEL_CORE_WIDTH),ds_scoreboard#(PARALLEL_CORE_WIDTH)) out_trans_imp;
When i conpile i get this error:
** Error: (vlog-13069) ** while parsing file included at …/uvm/serdes_tb_top.sv(7)
** while parsing file included at …/uvm/serdes_pkg.sv(7)
** while parsing file included at …/uvm/ds_uvc/ds_pkg.sv(14)
** at …/uvm/ds_uvc/ds_env.sv(12): near “#”: syntax error, unexpected ‘#’, expecting IDENTIFIER or ‘=’.
I have checked all the components just to see if i was missing any parameter but everything seems fine, could you please give me any suggestion??
Thank you
