Hello, I am compiling thhe UVM testbench and I am getting the following error:
** Error: ../config_policies/top_params_pkg.sv(13): (vlog-13006) Could not find the package (mgc_axi4_v1_0_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** Error: (vlog-13069) ** while parsing file included at ../config_policies/top_params_pkg.sv(16)
** at ../config_policies/axi4_master_0_config_policy.svh(10): near “cfg”: syntax error, unexpected IDENTIFIER, expecting ‘)’.
** Error: ** while parsing file included at ../config_policies/top_params_pkg.sv(16)
** at ../config_policies/axi4_master_0_config_policy.svh(18): (vlog-2164) Class or package ‘mgc_axi4_v1_0_pkg’ not found.
** at ../config_policies/axi4_master_0_config_policy.svh(20): (vlog-2164) Class or package ‘mgc_axi4_v1_0_pkg’ not found.
** Error: (vlog-13069) ** while parsing file included at ../config_policies/top_params_pkg.sv(17)
** at ../config_policies/utmi_utm_device_0_config_policy.svh(10): near “cfg”: syntax error, unexpected IDENTIFIER, expecting ‘)’.
** Error: ../config_policies/top_params_pkg.sv(36): Syntax error: ‘axi4_vip_config’ is not a type.
– Compiling package top_pkg
** Error: top_pkg.sv(11): (vlog-13006) Could not find the package (mgc_axi4_v1_0_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
** Error: ** while parsing file included at top_pkg.sv(18)
** at top_env_config.svh(12): Invalid type ‘utmi_utm_device_0_cfg_t’. Please check the type of the variable ‘utmi_utm_device_0_cfg’.
** Error: (vlog-13069) ** while parsing file included at top_pkg.sv(18)
** at top_env_config.svh(35): near “[”: syntax error, unexpected ‘[’, expecting ‘(’.
** at top_env_config.svh(36): (vlog-2730) Undefined variable: ‘TESTREGHS_map_entries’.
** Error: ** while parsing file included at top_pkg.sv(19)
** at top_env.svh(14): Invalid type ‘utmi_utm_device_0_agent_t’. Please check the type of the variable ‘utmi_utm_device_0’.
** Error: (vlog-13069) ** while parsing file included at top_pkg.sv(19)
** at top_env.svh(41): near “::”: syntax error, unexpected ::, expecting ‘;’.
** at top_env.svh(44): (vlog-2730) Undefined variable: ‘utmi_utm_device_0’.
** at top_env.svh(44): (vlog-2164) Class or package ‘utmi_utm_device_0_agent_t’ not found.
** at top_env.svh(44): (vlog-2730) Undefined variable: ‘utmi_utm_device_0_agent_t’.
** at top_env.svh(44): near “::”: syntax error, unexpected ::, expecting ‘;’.
** Error: ** while parsing file included at top_pkg.sv(21)
** at top_test_base.svh(12): Invalid type ‘utmi_utm_device_0_cfg_t’. Please check the type of the variable ‘utmi_utm_device_0_cfg’.
** Error: (vlog-13069) ** while parsing file included at top_pkg.sv(21)
** at top_test_base.svh(142): near “::”: syntax error, unexpected ::, expecting ‘;’.
** at top_test_base.svh(147): near “::”: syntax error, unexpected ::.
** at top_test_base.svh(149): (vlog-2730) Undefined variable: ‘utmi_utm_device_0_cfg’.
** at top_test_base.svh(149): (vlog-2164) Class or package ‘utmi_utm_device_0_cfg_t’ not found.
** at top_test_base.svh(149): (vlog-2730) Undefined variable: ‘utmi_utm_device_0_cfg_t’.
** at top_test_base.svh(149): near “::”: syntax error, unexpected ::, expecting ‘;’.
** at top_test_base.svh(150): (vlog-2730) Undefined variable: ‘utmi_utm_device_0_bfm_t’.
** at top_test_base.svh(154): (vlog-2164) Class or package ‘utmi_utm_device_0_config_policy’ not found.
** at top_test_base.svh(154): Identifier ‘utmi_utm_device_0_config_policy’ is not directly visible.
Found multiple Declaration of ‘utmi_utm_device_0_config_policy’ through wildcard imports from these packages : top_params_pkg, top_params_pkg
** at top_test_base.svh(154): Illegal to use typedef “utmi_utm_device_0_config_policy” as a variable.
** at top_test_base.svh(154): near “::”: syntax error, unexpected ::.
** Error: (vlog-13069) ../config_policies/top_params_pkg.sv(36): near “(”: syntax error, unexpected ‘(’, expecting class.
– Compiling module hvl_top
** Error: ** while parsing file included at hvl_top.sv(10)
** at test_packages.svh(8): (vlog-13006) Could not find the package (top_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.
I have checked the file but I did not find any mistake. Am I missing something? Could you please give me any suggestion??
Thank you
