Error Msg. Could not find member 'seq_item_export'
Hi all
i am a beginner in uvm. please correct me if any wrong.
The error message is
Error-[MFNF] Member not found
apb_agent.sv, 48
“this.seqr.”
Could not find member ‘seq_item_export’ in class ‘apb_rw_seq’, at
“apb_sequence.sv”, 41.
Here is a part of my code.
Many thanks in advance.
class apb_seq_item extends uvm_sequence_item;
	// items
	rand bit [31:0]	addr;
	rand bit [31:0]	data;
	rand bit [1:0]	mode;
			// Mode 0: Idle
			// Mode 1: Write
			// Mode 2: Read
			// Mode 3: Bulk Write
	     bit [31:0]	rdata;
	constraint	const_a{addr[31:0] >=0; addr[31:0] < 32'd256;};
	constraint	const_d{data[31:0] >=0; data[31:0] <= 32'hffff;};
	//constraint	const_m{mode[1:0] >=0; mode[1:0] <=2;};
	// construct
	function new(string name = "apb_seq_item");
		super.new(name);
	endfunction: new
endclass: apb_seq_item
class apb_bulk_seq extends uvm_sequence #(apb_seq_item);
	`uvm_object_utils(apb_bulk_seq)
	bit [2:0] bulk_count;
	// construct
	function new(string name = "apb_bulk_seq");
		super.new(name);
	// bulk write
	virtual task body();
		bulk_count = 7;
		if (bulk_count != 0) begin
			repeat (1) begin
				req = apb_seq_item::type_id::create("req");
				start_item(req);
				if(!req.randomize()) begin
					`uvm_error("RANFAIL", "Randomize failed.");
				finish_item(req);
				bulk_count --;
			bulk_count = 7;
endclass: apb_bulk_seq
class apb_rw_seq extends uvm_sequence #(apb_seq_item);
	`uvm_object_utils(apb_rw_seq)
	// construct
	function new(string name = "apb_rw_seq");
		super.new(name);
		//`uvm_info(get_type_name(),$sformatf("------ Signle Write Mode ------"),UVM_LOW)
		start_item(req);
		finish_item(req);
endclass: apb_rw_seq
class apb_seq extends uvm_sequence #(apb_seq_item);
	apb_rw_seq	rw_seq;
	apb_bulk_seq	bulk_seq;
	apb_seq_item	my_item;
	`uvm_object_utils(apb_seq)
	// construct
	function new(string name = "apb_seq");
		super.new(name);
	// bulk mode count reset
		if (my_item.mode == 3) begin
			`uvm_info(get_type_name(),$sformatf("------ Bulk Write Mode ------"),UVM_LOW)
			`uvm_do(bulk_seq)
		else if (my_item.mode == 1) begin
			`uvm_do(rw_seq)
		else if (my_item.mode == 2) begin
			`uvm_info(get_type_name(),$sformatf("------ Signle Read Mode ------"),UVM_LOW)
			`uvm_do(rw_seq)
			`uvm_info(get_type_name(),$sformatf("------ Idle Mode ------"),UVM_LOW)
			`uvm_do(rw_seq)
endclass: apb_seq
`include "apb_seq_item.sv"
`include "apb_sequence.sv"
`include "apb_driver.sv"
//`include "apb_monitor.sv"
class apb_agent extends uvm_agent;
	// instance
	apb_driver	driver;
	apb_rw_seq		seqr;
//	apb_monitor	monitor;
	`uvm_component_utils(apb_agent)
	// construct
		super.new(name, parent);
	endfunction: new
	// build
		super.build_phase(phase);
//		monitor = apb_monitor::type_id::create("monitor", this);
		//creating driver and sequence only for ACTIVE agent
		if(get_is_active() == UVM_ACTIVE) begin
			driver = apb_driver::type_id::create("driver",this);
          seqr = apb_rw_seq::type_id::create("seqr",this);
	endfunction: build_phase
	// connect
          driver.seq_item_port.connect(seqr.seq_item_export);
	endfunction: connect_phase
endclass: apb_agent
In reply to uvmbee:
I do not think you meant to declare in app_agent
apb_seq_item seqr;
I think you want
uvm_sequencer #(apb_seq_item) seqr;
In reply to uvmbee:
I believe your problem is imna body task:
You do not construct and genearte my_item objects.
You hav to construct it and generate items before you can evaluate it.
