Error: Macro `uvm_object_utils is undefined, error:undefined variable:uvm_config_db, error:near "#" : syntax error, unexpected '#'
In reply to Nishant Kumar:
Hi nishanth,
Thanks for reply.
I had done changes how you mentioned but i found again different error as below. Could you please help me out.
Error Report:
vlog -work work -vopt -sv -nocovercells D:/codes_on_questa/design_count.sv
QuestaSim vlog 10.0c Compiler 2011.07 Jul 21 2011
** Note: (vlog-2286) Using implicit +incdir+C:/questasim_10.0c/uvm-1.1/…/verilog_src/uvm-1.1/src from import uvm_pkg
** Note: (vlog-2286) Using implicit +incdir+C:/questasim_10.0c/ovm-2.1.2/…/verilog_src/ovm-2.1.2/src from import ovm_pkg
** Error: C:/questasim_10.0c/ovm-2.1.2/…/verilog_src/ovm-2.1.2/src/base/base.svh(25): (vlog-2163) Macro const is undefined. ** Error: C:/questasim_10.0c/ovm-2.1.2/../verilog_src/ovm-2.1.2/src/base/ovm_version.svh(26): (vlog-2163) Macro OVM_VERSION_STRING is undefined.
** Error: C:/questasim_10.0c/ovm-2.1.2/…/verilog_src/ovm-2.1.2/src/base/ovm_version.svh(26): near “;”: syntax error, unexpected ‘;’
