In reply to dirkh:
Hello Dirkh,
Well, yeah. I started running the matlab examples. Since then I am trying to integrate it to my testbench. I am using centos 6.7, so in theory what works for you should work for me.
The thing with the 32/64 bit thing. When I use the “-64” parameter from a “.do” file it does not work. However if I set it within a makefile(as in the example) it works.
Regarding the FTP server. I cannot access to it. I am not using any proxy (as far as I know althought I am in the university library). Would it work if I download an FTP client and send the file to that adress?
EDIT: I have tried to connect to the FTP server using the ftp command although It did not connect…
I am going to start from the beginning as well, lets see where the mistake is, although were I started the testbench was working. That is why I have the impression the problem is when integrating matlab.
Thanks Dirkh, I really appreciate your help.
Antonio
