for code-
module type_def;
typedef struct {int i;} tps;
`define dps struct {int i;};
tps p1,p2;
`dps p3;
I am getting following error-
type_def.sv(8): near “;”: syntax error, unexpected ‘;’, expecting '(
I cant understand the reason for it.
Please use SystemVerilog tags around your code(I added them for you), and I assume line 8 was
`dps p3;
It would have helped if you pointed that out.
The reason for the syntax error is the extra semicolon at the end of your **define dps**. The becomes part of the text replaced by dps.
Thanks dave_59. I will remember tags next time.
