Error casting p_sequencer
Hello,
I’m extending a new sequence from the existing sequence in the UVC. Can you please let me know what is causing this Error:
a_b_pkg::a_b_seq.m_set_p_sequencer uvm_test_top.tb.vseqr.m_test_seq.m_im_b_seq Error casting p_sequencer, please verify that this sequence/sequence item is intended to execute on this type of sequencer
The existing sequence in the UVC has p_sequencer declared and all the connections/setup has no issue as I’m able to simulate a_b_seq without any errors. The issue is only with the newly extended sequence m_im_b_seq. Can you guide how to set the sequencer for the newly extended sequence.
Thanks!
In reply to k95129:
See if this is your problem: Runtime Fatal Error : p_sequencer can't be casting from a parameterized sequencer | Verification Academy
Is this error solved?
