Equivalent expression for if-else property_expression
Hi All,
if (boolean_expression) property_expr;
// is equivalent to
booloen_expression |-> property_expr;
I was wondering what would be the equivalent expression for if-else property_expression ?
I tried the following code : edalink , here is what I observe ::
(a) For +define+SAME when all the 3 clock are of same clock period , the output is the same in both cases i.e using if-else as well the equivalent expression the output match
(b) However when the clock periods are different , I observe different output across tools.
For 1st stimulus i.e +define+M1 :
Using if-else the assertion passes at T:7 however when using the equivalent expression,
2 tools show pass at T:5 and 15 whereas only one tool shows pass at T:7 ( same o/p as if-else )
I understand that we don’t discuss tool related issues but I am curious on how the expression :
ap1:assert property ( ( @(posedge clk0) b |-> @(posedge clk1)  a  ) or ( @(posedge clk0) !b |-> @(posedge clk2) c )  )
is evaluated ?
On 1st posedge of clk0 at T:5 , one of the antecedent is vacuously true . Would the or operator return true due to this ? i.e resulting in pass at T:5 and 15
The output matches the if-else if I try using expression :
ap1:assert property (  @(posedge clk0) 1 |-> ( @(posedge clk1) a or  @(posedge clk2) c )  )
But I doubt that this can be termed as the equivalent expression for if-else in general
In reply to Have_A_Doubt:
// For (if(expr1) prop; else (prop2) I would write 2 properties
// 1) it's clearer and easier to debug
// I personally, as a matter of style I prefer to use the |-> instead of the "if
// Also, avoid property declarations if you are not using local variables or if
// you are not reusing the property.
// Discussion of
                      ( @(posedge clk0) !b |-> @(posedge clk2) c )  );
// This assertion can never fail because the antecedent of one of the properties is a NO MATCH
// causing it to be vacuously true.
// Discussion of
// But I doubt that this can be termed as the equivalent expression for if-else in general
// IT IS NOT equivalent to the if else.
// KISS, write 2 separate assertions, one for each value of the expression of the antecedent.
Ben@systemverilog.us
or Links_to_papers_books - Google Docs
