There is this statement in SV 2017 IEEE std.
Enumerated variables are type-checked in assignments, arguments, and relational operators. Enumerated variables are auto-cast into integral values, but assignment of arbitrary expressions to an enumerated variable requires an explicit cast.
Does this mean that, I have to do explicit typecasting of the conditional expression statement in the following code snippet?
typedef enum logic [1:0] {
IDLE, TRANSFER, ACK, NACK
} state_t ;
state_t curr_state, nxt_state ;
logic is_ack_received ;
always_comb begin
case (curr_state)
nxt_state = (is_ack_received)? ACK : NACK ; // Throws compiler error
endcase
The compiler which I use (iverilog) forces me to use, saying explicit type casting is required since the condition uses a 4 state logic variable.
nxt_state = state_t'((is_ack_received)? ACK : NACK) ;
Is this required to do so as per the LRM?
