Either the path is incorrect, or you may not have PLI/ACC visibility to that object
I’m trying to perform backdoor write but while it tries to perform uvm_hdl_deposit on the given path I get the following error Unable to deposit value to ‘<hdl_path>’ Either the path is incorrect, or you may not have PLI/ACC visibility to that object. The path is accurate, how can I overcome the visibility error? I am using Visualizer to compile and run tests. Any advice would be appreciated. TIA
In reply to Vaishnavi Balasubramanian:
This is likely an optimization object visibility issue.
This Mentor/Siemens EDA sponsored public forum is not for discussing tool specific usage or issues. Please read your tool’s user manual or contact your tool vendor directly for support.
