queue q[$] = {5,1,2,3,4,5}
index ind[*] = {0,0,1,0,1,0}
How can I edit q to have zeros on the index where associative ind has 1?
In reply to Aashish Itani:
Firstly, the declaration of queue & associative array is not proper. I hope your question is in associative array in whichever index you have 1, in that particular index of queue you should have zeros.
module test;
int q[$] = {5,1,2,3,4,5};
int ind[int]={0:0,1:0,2:1,4:0,7:1,10:0};
int idx;
int idx1;
initial
if(ind.first(idx))
if(ind[idx]==1)
q.insert(idx,0);
if(ind.last(idx1))
if(ind[idx1]==1)
q.insert(idx1,0);
while(idx!=idx1)
if(ind.next(idx))
if(ind[idx]==1)
q.insert(idx,0);
$display("%p,%p",q,ind);
Thanks & Regards,
Shanthi V A
In reply to shanthi:
Thanks a lot.
// modify q to have zeros on the index where associative array has 1
module test;
int q[$] = {5,1,2,3,4,5,7,11,2};
int ind[int] = {0:1,3:0,5:1,6:0,8:1};
int q1[$];
q1 = ind.find_index with(item == 1);
$display("q1 = %0p", q1);
foreach(q1[i]) begin
q.insert(q1[i], 0);
$display("q = %0p", q);
q.delete(q1[i]+1);
endmodule : test
