class base;
int a = 5;
class extend extends base;
int b = 1;
base base;
extend extend;
extend = new();
base = new();
$cast(extend, base);
$display(extend.a);
You cannot cast a base class variable to an extended class variable when the base class variable does not contain a type compatible object. extend.b would not exist. Please review the link I gave you in your previous question.
In reply to peter:
Thanks for reply.
if base_handle is a reference to derived class, and i use the $cast(extend_handle,base_handle), it is permitted. if base_handle is not a reference to derived class , it is not permitted using $cast(extend_handle,base_handle).
is it correct?
That is correct for your example. I strongly suggest you see my SystemVerilog OOP course on classes for more details on up-casting versus down-casting and how that relates to inheritance.
In reply to peter:
