Thanks Ben, this was certainly helpful.
For the moment lets consider the following code:
- qb is a reg which is assigned continuously. (I read this is not allowed)
- q is a reg procedurally assigned from 2 different always blocks. (I read that the same reg cannot be assigned from 2 different always blocks)
yet this compiles with no issue if we try on EDA playground. Could you help me understand why?
// Design
// D flip-flop
module dff (clk, reset,
d, q);
input clk;
input reset;
input d;
output q;
reg qb;
reg q;
assign qb = ~q;
always @(posedge clk)
// Assign D to Q on positive clock edge
q <= d;
always @(posedge reset)
if (reset) begin
// Asynchronous reset when reset goes high
q <= 1'b0;
// Testbench
module test;
reg clk;
reg reset;
reg d;
wire q;
wire qb;
// Instantiate design under test
dff DFF(.clk(clk), .reset(reset),
.d(d), .q(q) );
// Dump waves
$dumpfile("dump.vcd");
$dumpvars(1);
$display("Reset flop.");
clk = 0;
reset = 1;
d = 1'bx;
display;
$display("Release reset.");
d = 1;
reset = 0;
display;
$display("Toggle clk.");
clk = 1;
display;
task display;
#1 $display("d:%0h, q:%0h,",
d, q);
Same code can be run on EDA playground at this link : Your text to link here…
Thanks for the help!
