Hi All,
I want to drive the output (internal to TOP) of a module defined in the interface file using a transaction item(a field inside uvm_sequence_item) in my sequence file.
However I see contention on the output signal due to two drivers driving the signal.
Is there a way I can use statement like below in my sequence (by forcing the value in the output port somehow) :
force mon_if.output_port = tr.output_port ;
if I use above statement I get following error :
“Error-[DTINPCNS] Dynamic type in non-procedural context
“force this.mon_if.output_port = tr.output_port;”
Argument: tr.output_port
Class data is not allowed in non-procedural context.”
Thanks for your time and help
