when i write a command of vsim to simulate my top module , there are a lot of warnings appear and here they are :
vsim work.top
vsim work.top
Loading sv_std.std
Loading work.uvm_pkg
Loading work.top_sv_unit
Loading work.top(fast)
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_hdl_check_path’. The search list was empty.
Using -sv_lib, -sv_root, and -sv_liblist arguments can provide a search list
of shared libraries that will be used to resolve user specified functions.
Time: 0 ns Iteration: 0 Instance: /top File: top.sv
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_hdl_deposit’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_hdl_force’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_hdl_release_and_read’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_hdl_release’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_hdl_read’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_get_next_arg_c’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_get_tool_name_c’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_get_tool_version_c’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_regcomp’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_regexec’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dpi_regfree’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_re_match’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_dump_re_cache’. The search list was empty.
** Warning: (vsim-3770) Failed to find user specified function ‘uvm_glob_to_re’. The search list was empty.
then , when i write a command of run all , that is what appears :
run -all
** Fatal: (vsim-160) D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh(27): Null foreign function pointer encountered when calling ‘uvm_dpi_get_next_arg_c’
Time: 0 ns Iteration: 0 Process: /uvm_pkg File: D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh
Fatal error at D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh line 27
HDL call sequence:
Stopped at D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh 27
called from D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/dpi/uvm_svcmd_dpi.svh 32
called from D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/base/uvm_cmdline_processor.svh 245
called from D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/base/uvm_cmdline_processor.svh 61
called from D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/base/uvm_root.svh 306
called from D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/base/uvm_root.svh 286
called from D:/Flash_mem/Questa_setUp/verilog_src/uvm-1.1d/src/uvm_pkg.sv 0
i am working on Questasim 10.0b , i have also compiled UVM package every time i use it and i have try alot of things to solve this problem and nothing is succeeded , so i will be very grateful if you supply me with a previous tried solution,
