Hello,
I am trying to use C functions in SV environment.
I successfully compiled and set up all the DPI related things.
The C function I want to use is:
int my_dpi(char *arg, char **ret)
{ printf("DPI Received arg: %s", arg);
sprintf(*ret,"HELLO");
return TRUE;
In SV i import the function as follows:
import "DPI-C" context function int my_dpi(input string arg, output string ret);
And then I try to use it as follows:
res = my_dpi("in_text", ret);
`uvm_info("DPI DBG", $sformatf("Arg: %s RES: %0d rsp: %s", arg, res, ret), UVM_NONE);
With this setup, i have a runtime failure coming from the DPI (Bad handle reference).
By changing how the C function uses the char **ret, I don’t get the error, but also miss the “ret” value.
ret = "HELLO";
return TRUE;
I looked into compatibility between SV and C types for DPI, but could not find a clear solution for “char **ret”, which is a “pointer to char pointer” if I am not wrong.
Is there a solution to use the original C function?
Maybe I am declaring the DPI with wrong SV types?
Luca
