I have one question regarding fork-join let’s say I have one automatic variable “a”. In fork-join, I have two threads in one thread “a” is incrementing, and in another thread “a” is decrementing. I am expecting the display one answer to be 3 and display 2 answer to be 1 because I am thinking each time “a” is called it will allocate memory. Can anyone correct me if my thinking is wrong.
initial
automatic int a = 2;
begin //: 1
a = a + 1;
$display("1 %d", a);
begin //: 2
a = a - 1;
$display("2 %d", a);
join
run -all
1 3
2 2
exit
along with that what if we don’t have an automatic keyword and what is the behaviour of the code? I think it is a race condition correct me If I am wrong.
Thank You.
In reply to marathuteja:
In this particular example, it makes no difference if ‘a’ is declared with a static or automatic lifetime. There is only one instance of the variable ‘a’ shared between the two threads. And yes, it is a race condition which thread starts first
If we take an automatic task or function, when we call the function or task each time then it allocates space each time for that task or function.
for example :
function automatic int factorial(int N);// when we call this function space is created for factorial
if(N>2)
return factorial(N-1) * N; // again it will create another space here
return 1;
function int factorial(int N);// when we call this function space is created for factorial
if(N>2)
return factorial(N-1) * N; // the created space is used again here right.
return 1;
Likewise, when automatic variables get space allocated each time can you explain with an example
