An observation during the simulation profiling of my SOC ENV is that, uvm_top.find() consumes lot of simulation time, like 80% of the sim time. This is being used to extract the handle of a component in our ENV.
Wanted to understand if uvm_top.fin() in general consumes such huge simulation times for any UVM ENV…?
And if so, what would be other mechanisms to achieve the same and improve simulation performance?
In reply to Byreddynaresh:
I believe it is hard to give you a clean answer. But all search processes might consume time and performance. For me it is unclear why you need the find command. I never use this command when constructing the testbench. In my eyes it is only required for debugging, when you are missing certain components.
Are you calling uvm_top.find() more than once?
In reply to dhserfer:
At SOC, I have been using uvm_top.find() to get the reference/instance of an IP level UVM component. I’m using this extracted hierarchy to invoke a function within that IP level UVM component.
I could have directly used the hierarchical path to refer to that IP UVM component instance and accessed its function, but being an SOC ENV, i didn’t want to hard-code the usage.
EX : Currently i’m using it as:
longint unsigned my_addr; // local variable to store address
byreddy_env abc; // byreddy_env is my IP UVM component
$cast(abc,uvm_top.find(“*u_byreddy_env”)); // u_byreddy_env is instance of byreddy_env
my_addr = abc.get_system_address();
@ dhserfer : yes i use this call to uvm_top.find() many times as the above code gets executed lot of times.
Could you please let me know better approach for the same.
BTW, thanks a lot for replying.
UVM is a very regular approach with a fixed architecture based on agents or sub-envs, i.e. there is always a well-dfined path to any component in this hierarchy. Using a hierarchical here is not a limitation.
Is there any reason why you can’t save the handle “abc”? If abc==null then do the ‘find’ and save the handle.
@dhserfer : If i understood your comment rightly, this is the way your are suggesting:
class xyz
// xyz class specific
byreddy_env handle_byreddy;
function soc_get_address();
if(handle_byreddy == null) begin
if( !$cast(abc,uvm_top.find(“*u_byreddy_env”)) ) // u_byreddy_env is instance of byreddy_env
`uvm_fatal(//the object doesn’t exist)
handle_byreddy = abc;
my_addr = handle_byreddy.get_system_address();
endfunction // function soc_get_address();
endclass //class xyz
Please let me know.
Yes, except the component handle is returned by uvm_top.find(“*u_byreddy_env”)) and cast to abc, so there’s no reason to create another handle.
class xyz
byreddy_env abc;
if(abc == null)
if( !$cast(abc,uvm_top.find("*u_byreddy_env")) )
`uvm_fatal(...)
Your inputs really helped.
Thanks a lot Guys.
