I was trying to do simple user defined “unpack”, I have tried to do “unpack_ints”.
Issue is unpack didn’t happen. I am not sure what I have missed. But when I tried changed
input array type to “byte” and used “unpack_bytes” it worked as per expectation. I am not
sure why “unpack_ints” didn’t work.
Code:
`include "uvm_macros.svh"
package my_pkg;
import uvm_pkg::*;
class Packet extends uvm_sequence_item;
rand bit [7:0] length;
rand bit [7:0] da;
rand bit [7:0] sa;
rand bit [7:0] data[];
function new(string name = "");
super.new(name);
endfunction : new
function void do_unpack(uvm_packer packer);
int sz;
super.do_pack(packer);
da = packer.unpack_field_int($bits(da));
sa = packer.unpack_field_int($bits(sa));
length = packer.unpack_field_int($bits(length));
data.delete();
data = new[length];
foreach(data[i])
data[i] = packer.unpack_field_int(8);
endfunction : do_unpack
endclass : Packet
endpackage: my_pkg
module test;
import uvm_pkg::*;
import my_pkg::*;
Packet pkt2 = new("pkt2");
int unsigned pkdbytes[];
initial
repeat(1)
pkdbytes = new[9];
$display("Size of pkd bits %d",pkdbytes.size());
for(int i=0; i < pkdbytes.size(); i++)
pkdbytes[0] = 'hFF;
pkt2.unpack_ints(pkdbytes);
pkt2.print();
$display("pkt2.da:%0h, pkt2.sa:%0h",pkt2.da,pkt2.sa);
Output:
Size of pkd bits 9
Name Type Size Value
pkt2 uvm_sequence_item - @456
pkt2.da:0, pkt2.sa:0
Karthik
