Hi all ,
I have the following code ::
class Base ;
rand bit [2:0] b ;
constraint B { b == 0 ; }
class Ext1 extends Base ;
constraint B { b == 1 ; } // Override Constraint "B"
Base b ;
Ext1 e1 ;
e1 = new();
b = e1 ;
b.B.constraint_mode(0); // If it behaves as Virtual it would turn-off Constraint B in Class Ext1
repeat(3)
if ( e1.randomize() )
$display(" Success with %p as Constraint Block B is %s ",b, e1.B.constraint_mode() == 1 ? "ON" : "OFF");
Since Base class can’t point to extended class properties and constraint blocks are class members ,
Should it turn-off Constraint B in extended class ? If yes , won’t this make Constraint Blocks similar to a Virtual method ?
Since you declared constraint of derieved class with same constraint name it has more say over parent . Basically it overides the parent constraint .
In reply to Sv-hustler:
Yes that part I understand .
Question is whether b.B.constraint_mode(0) points to Constraint in object e1 ? .
Is yes isn’t that illegal since base class can’t point to extended class properties ?
In reply to Have_A_Doubt:
Constraints are not virtual, the randomize() method is. When you declare a constraint with the same name in an extended class, you hide the original constraint from randomize. You are still able to access the constraint_mode of both constraints, but only the mode of the extended constraint will have an effect. The base constraint is not visible.
Just want to revisit this topic and have a little bit more clarification.
class base;
randc int a;
constraint d { a < 10;}
virtual function void display();
$display("(%m) %0d",a);
post_display();
function post_randomize();
a+=100;
function void post_display();
$display("base post_display");
class ext extends base;
constraint d { (a > 10) && (a < 20) ;}
post_display();
a+=200;
$display("ext post_display");
module top();
base b1;
ext e1;
e1 = new();
void'(e1.randomize());
e1.display();
b1 = e1;
void'(b1.randomize());
b1.display();
The above code prints the result as,
($unit_0x42828247.ext.display) 217
ext post_display
($unit_0x42828247.ext.display) 218
ext post_display
Here what I observe is that even though constraints and the function “post_display” are not virtual, because of the fact that these are called from virtual methods, they somehow act as virtual themselves in this context?
Finding these concepts a little bit confusing.
Shoudnt the post_display() call from base handle object point to the base handle definition of post_display() ?
