I have a 64 bit variable and occasionally I want to use it for 32 bit variable. Now when printing the variable it prints whole 64 bits, but in case when I use for 32 bit purpose, I want to just print the lower half of 64 bits .
For example,
bit [63:0] var_64;
var_64 = 64'h1234_5678_aaaa_bbbb;
$display("var = %x",var_64); This is displaying "1234_5678_aaaa_bbbb" , which is good
var_64 = 32'h1234_5678;
$display("var = %x",var_64); This is displaying "0000_0000_1234_5678" , but I want just lower 32 bit "1234_5678" , and not 0s in front.
Thank you,
Mega
In reply to megamind:
$display("var = %x",var_64[31:0]);
$display("var = %x",32'(var_64));
Thank you Dave. Is there any way to play with %4x or %8x etc, something like that, without casting or part select, as originally I was thinking that it is possible to control the precision points. This is just for curiosity otherwise solution is going to work.
If you can guarantee the upper bits are all zero, then %8x would also work. Remember that %8x is interpreted to be the minimum field width. If any of those upper bits are non-zero, they would be displayed.
That is perfect! and that was the solution I was actually looking for, somehow I got confused earlier on the interpretation of %8x etc, but now its better clear. Thank you very much Dave.
