I’m designing a controller FSM for my MIPS multicycle CPU. I want to display the signals state and controls that are in the module maindec. In my testbench I’m instantiating the top module controller. I tried making these signals internal to the controller module and passing them to maindec but I get an error because I cannot update inputs in the module. I also tried instantiating maindec in my testbench but the signals just remain as don’t care values. How can I display them in my waveform?
CODE:
module controller(input logic clk, reset,
input logic [5:0] op, funct,
input logic zero,
output logic pcen, memwrite, irwrite, regwrite,
output logic alusrca, iord, memtoreg, regdst,
output logic [1:0] alusrcb, pcsrc,
output logic [2:0] alucontrol);
logic [1:0] aluop;
logic branch, pcwrite;
// Main Decoder and ALU Decoder subunits.
maindec md(clk, reset, op,
pcwrite, memwrite, irwrite, regwrite,
alusrca, branch, iord, memtoreg, regdst,
alusrcb, pcsrc, aluop);
aludec ad(funct, aluop, alucontrol);
// ADD CODE HERE
// Add combinational logic (i.e. an assign statement)
// to produce the PCEn signal (pcen) from the branch,
// zero, and pcwrite signals
assign pcen = (branch && zero) || (pcwrite);
//MAINDEC:
module maindec(input logic clk, reset,
output logic pcwrite, memwrite, irwrite, regwrite,
output logic alusrca, branch, iord, memtoreg, regdst,
output logic [1:0] aluop);
parameter FETCH = 4'b0000; // State 0
parameter DECODE = 4'b0001; // State 1
parameter MEMADR = 4'b0010; // State 2
parameter MEMRD = 4'b0011; // State 3
parameter MEMWB = 4'b0100; // State 4
parameter MEMWR = 4'b0101; // State 5
parameter RTYPEEX = 4'b0110; // State 6
parameter RTYPEWB = 4'b0111; // State 7
parameter BEQEX = 4'b1000; // State 8
parameter ADDIEX = 4'b1001; // State 9
parameter ADDIWB = 4'b1010; // state 10
parameter JEX = 4'b1011; // State 11
parameter LW = 6'b100011; // Opcode for lw
parameter SW = 6'b101011; // Opcode for sw
parameter RTYPE = 6'b000000; // Opcode for R-type
parameter BEQ = 6'b000100; // Opcode for beq
parameter ADDI = 6'b001000; // Opcode for addi
parameter J = 6'b000010; // Opcode for j
logic [3:0] state, nextstate;
logic [14:0] controls;
// state register
always_ff @(posedge clk or posedge reset)
if(reset) state <= FETCH;
else state <= nextstate;
// ADD CODE HERE
// Finish entering the next state logic below. The first
// two states, FETCH and DECODE, have been completed for you.
// next state logic
always_comb
case(state)
FETCH: nextstate = DECODE;
DECODE:
case(op)
LW: nextstate = MEMADR;
SW: nextstate = MEMADR;
RTYPE: nextstate = RTYPEEX;
BEQ: nextstate = BEQEX;
ADDI: nextstate = ADDIEX;
J: nextstate = JEX;
default: nextstate = 4'bx; // should never happen
endcase
// Add code here
MEMADR:
case(op)
LW: nextstate = MEMRD;
SW: nextstate = MEMWR;
default: nextstate= 4'bx;
endcase
MEMRD: nextstate = MEMWB;
MEMWB: nextstate = FETCH;
MEMWR: nextstate = FETCH;
RTYPEEX: nextstate = RTYPEWB;
RTYPEWB: nextstate = FETCH;
BEQEX: nextstate = FETCH;
ADDIEX: nextstate = ADDIWB;
ADDIWB: nextstate = FETCH ;
JEX: nextstate = FETCH;
endcase
// output logic
assign {pcwrite, memwrite, irwrite, regwrite,
alusrcb, pcsrc, aluop} = controls;
// ADD CODE HERE
// Finish entering the output logic below. The
// output logic for the first two states, S0 and S1,
// have been completed for you.
always_comb
case(state)
FETCH: controls = 15'h5010;
DECODE: controls = 15'h0030;
// your code goes here
MEMADR: controls = 15'h0420;
MEMRD: controls = 15'h0520;
MEMWB: controls = 15'h0da0;
MEMWR: controls = 15'h25a0;
RTYPEEX: controls = 15'h0582;
RTYPEWB: controls = 15'h0d42;
BEQEX: controls = 15'h0745;
ADDIEX: controls = 15'h0564;
ADDIWB: controls = 15'h0c24;
JEX: controls = 15'h4428;
default: controls = 15'hxxxx; // should never happen
endcase
// ALUDEC:
module aludec(input logic [5:0] funct,
input logic [1:0] aluop,
// ADD CODE HERE
// Complete the design for the ALU Decoder.
// Your design goes here. Remember that this is a combinational
// module.
// Remember that you may also reuse any code from previous labs.
always_comb
case(aluop)
2'b00: alucontrol = 3'b010; // add
2'b01: alucontrol = 3'b110; // sub
2'b11: alucontrol = 3'b001; // OR
default:
case(funct) // RTYPE
6'b100000: alucontrol = 3'b010; // ADD
6'b100010: alucontrol = 3'b110; // SUB
6'b100100: alucontrol = 3'b000; // AND
6'b100101: alucontrol = 3'b001; // OR
6'b101010: alucontrol = 3'b111; // SLT
default: alucontrol = 3'bxxx; // ???
endcase
endcase
TESTBENCH:
module testbench();
logic clk, reset, zero, pcen,pcwrite,branch;
logic [5:0] op, funct;
logic [3:0] state;
logic [2:0] alucontrol;
logic [1:0] aluop;
logic memwrite, irwrite, regwrite,alusrca, iord, memtoreg, regdst;
logic [1:0] alusrcb, pcsrc;
controller dut(.clk(clk), .reset(reset), .op(op), .funct(funct)
, .zero(zero), .alucontrol(alucontrol), .pcen(pcen)
, .memwrite(memwrite), .irwrite(irwrite), .regwrite(regwrite)
, .alusrca(alusrca), .iord(iord), .memtoreg(memtoreg)
, .regdst(regdst) , .alusrcb(alusrcb), .pcsrc(pcsrc));
maindec dut_1(.clk(clk), .reset(reset), .op(op),.pcwrite(pcwrite),.memwrite(memwrite), .irwrite(irwrite), .regwrite(regwrite)
,.alusrca(alusrca),.branch(branch),.iord(iord),.memtoreg(memtoreg), .regdst(regdst) , .alusrcb(alusrcb), .pcsrc(pcsrc),.aluop(aluop));
always
clk = 1; # 5;
clk = 0; # 5;
initial
reset = 1; #10;
reset = 0;
op = 6'b000100;
funct= 6'b100010;
zero = 1; #10;
