Is it possible to disconnect an RTL block during simulation?
Please refer the diagram via the below link:
As depicted, the DUT interface is driven by 2 blocks:
- UVM spi agent (driver) and
- RTL spi Driver
The spi interface needs to be driven either by RTL spi driver OR UVM spi driver
Traditional Approach:
I can use an `ifdef to prevent the instantiation of the RTL spi driver block so that the interface is driven only by the UVM driver.
The problem with this approach is when a test fails with uvm spi driver and if I need to use the RTL spi driver, I need to re-compile.
Recompiling will not guarantee the reproduction of the scenario (randomization) even if we use the seed number.
Requirement:
It’ll be great to compile the RTL spi driver.
Then control the driving of the spi interface either from the UVM driver or RTL driver based on the simulation directive. This way I can use any driver, without having to recompile.
Could you please guide me in this regard?
Thank you,
Muneeb Ulla Shariff
