Hi all,
Can anyone help me how to remove the file line and line number by using the `UVM_INFO.
I’m used the -UVM_REPORT_DISABLE_FILELINE in makefile. But, there is no change to identify. Is any another way to achieve that.
Siva Prasad
Hi all,
Siva Prasad
In reply to Siva91221:
The correct macro to use is UVM_REPORT_DISABLE_FILE_LINE.
This macro is only used when compiling the UVM library. You will need to compile the UVM library instead of using a tool-specific version.
I’m not sure why you would want to remove the line number and file name from the log file. It’s better to post-process your log file.
In reply to cgales:
Ok. Just I wann to check that macro how it is working. Thank you so much.
Siva Prasad
