Option1
//Configuration : disable subsequencers sequence
uvm_config_db #(uvm_sequence_base)::set(this, " .cpu_seqr_phase", “default_sequence”, null);
Option2:
virtual task start_item (
uvm_sequence_item item,
int set_priority = -1,
uvm_sequencer_base sequencer = null )
I want to disable the sequence/sequencer, can I use option2 like this?
start_item (tx, -1, null);
I was trying to find available options to disable the default sequencer/sequence, May I know which is recommended?
Kindly advice.
Question2:
Once the particular sequence/sequencer is disabled, how can it be enabled back?
Like, just calling
start_item(tx) or `uvm_do(tx)
Will this make the sequence/sequencer enabled back?
Thank You,
Mahesh
