Hello,
Can I use disable iff in an immediate assertion? Example code below
always @(signal1)
example: assert ( disable iff(signal2 === 3'b011) $rose(signal3) |-> $rose(signal4) );
else $error ("ERROR");
Hello,
always @(signal1)
In reply to sj1992:
Did you try it?
You cannot use disable iff or $rose (or any sampled function) because there is no inferred clock—it is instantaneous.
Then what should we use to disable immediate assertion instead of disable iff ?
like : disable iff ( reset==1’b1 || $isunknown(reset)
In reply to Himanshu m soni:
An immediate assertion is just a procedural statement, not a process that needs to be disabled. You can use a conditional branching statement like if to avoid executing it.
Thanks a lot Dave
