I am trying to achieve when using fork join if any of two threads are completed, fork join has stop. To acheive above functionality I used combination of events and diable fork construct.
event a, b, c;
initial
#10 $display("%t 1st process", $time);
-> a;
#20 $display("%t 2nd process", $time);
->b;
#30 $display("%t 3rd process", $time);
->c;
int count='0;
forever
@(a or b or c)
count++;
$display("%d", count);
if(count == 32'd2)
$display("disable fork");
disable fork;
join
$display("Completed");
output :
10 1st process
1
20 2nd process
2
disable fork
30 3rd process
Completed
Can anyone help me why my code is not working at 2 I can see display of disable fork, but fork is not getting disabled.
event a, b, c;
initial
$dumpfile("dump.vcd"); $dumpvars;
fork: my_fork
-> a;
->b;
->c;
static int count='0;
forever
@(a or b or c)
count++;
if(count == 32'd2)
disable my_fork;
join
/*run -all
# 10 1st process
# 1
# 20 2nd process
# 2
# disable fork
# Completed
# exit
Ben Cohen Ben@systemverilog.us
What’s happening here is that the disable fork is killing all the threads swapned by the parent fork, but doesn’t kill the parent fork itself.
You are working around that by using a “label”. Note that using a “label” isn’t foolproof either, you may end up running the fork with multiple instances of the class, and all the “labels” will get killed, which may not be what you want. So keep that in mind.
I would prefer the following code instead :
event a, b, c;
initial
fork begin//isolator
bit disable_fork_condition;
-> a;
->b;
->c;
int count='0;
while(1)
@(a or b or c)
count++;
if(count == 32'd2)
disable_fork_condition = 1;
break;
join_any
wait(disable_fork_condition == 1);
disable fork;
end join //isolator
What’s happening here is that the disable fork is killing all the threads swapned by the parent fork, but doesn’t kill the parent fork itself can you expplain this i didnt understand.
