I am very much new in UVM. I am trying to understand some of the terminology. I checked the cookbook, but still have the confusion. I am writing down my conclusion, please correct me.
- Sequence item: It’s a individual transaction, such as only read, or only write. Transaction is known as Sequence item in UVM.
- Sequences: It’s a collection of sequence items, such as read, write.
- Test: There are two test in my understanding in uvm, sequence sometimes called as Test, since it do a particular set of operation. And other
Test is what Instantiate the environment, and further agents etc.
(Now what test is called as what test officially to avoid the confusion?)
I would really appreciate if anyone can explain me these terminology.
Regards,
Pankaj
In reply to papatel:
To correct you
(1) a sequence item is a transient object which contains data members and methods.
(2) a sequence is also a transient object which creates seq_items or executes other sequences,
(3) the test is a componnet which belongs to the UVM topology. It executes one or more sequences to verify certain DUT functionality. It can be configured with respect to the fuctionality.
Hi chr_sue,
So
1.sequence_item are just a class having data members and methods, method can have both read and write (for example)?
2.Sequence are constructor for sequence_item?
3.A sequence can be replaced for test in common saying?
Regards,
Pankaj
Yes a sequence item is a class. But it is a transient obejct. This will be cerated at any time and destroyed after ist has been processed.
A sequence is an extension of the seq_item. It is also transient. It describes how the sequence items will be generated.
A sequence and the test are completely different things. A test is a component object. It is created at runtime 0 and exists until the simulation hes been finished. In the test you can start 1 or more sequences. A component belongs to the testbench topology.
So a sequence_item will define only methods, but sequence will defines ordering of those methods? Is that correct understanding?
Regards,
Pankaj
Suppose we have following transactions, all these are method written different in sequence_item.
1.Read 2.Write 3.Reset 4.Add
(Sequence_item1) (Sequence_item2) (Sequence_item3) (Sequence_item4)
So sequence can be, combination of any of the above, such as (1,2) or (2,3), which will first construct them, then bundle it so as to call them as sequence1, sequence2. and then will be feeded to driver through sequencer, and sequencer can send sequence2 first and sequence1 (arbitrate). Is it correct understanding now?
Regards,
Pankaj
