Difference between pre callback and post callback
Can anyone explain in detail pre callback and post callback. What feature we define in both of them?
Please I need it urgently … Am having confusion abt it
In reply to pmehro:
There are many different kinds of callbacks in UVM for very advanced usage. We normally recommend against using them. We prefer that you use the Object-Oriented virtual method extension mechanism to add functionality. Can you explain where in particular you are seeing the need to use callbacks?
Actually this question was asked to me in Interview. And I went through callback chapter in SYSTEMVERILOG FOR VERIFICATION A Guide to Learning the Testbench Language Features Page no 236 they mentioned of post and pre callback mechanism I could not understand where to use them…
In reply to pmehro:
In that case, there is nothing special about pre- and post- callbacks. It simply is a place to add functionality before and after a particular statement.
Thanks for info. Can you please provide some sample code and some scenario where we can use it.
In reply to pmehro:
I don’t recommend using them, so no example. Instead, I recommend using the standard OO principal of inheritance and virtual methods.
class A;
virtual task Transmit;
// stuff to transmit
class Aext extends A;
// statements that would have been in the pre_ callback go here
if (some_expression)
   super.Transmit() // call the base method, or not
// statements that would have been in the post_ callback go here
Hi @dave_59,
Could you please elaborate why you don’t recommend using callbacks?
In which cases it behaves odd? Or breaks functionality?
Michael
After all these years, I’ve come to soften my recommendation. Each style has its pros and cons. I would also suggest a third option: the decorator pattern.
1. Callbacks
Usage: Typically implemented using interfaces with virtual methods or class handles passed as arguments to inject behavior.
:white_check_mark: Pros:
  • Flexible behavior injection: You can swap out implementations without modifying the generator logic.
  • Promotes decoupling: Useful in testbenches where stimulus and response are separated.
:cross_mark: Cons:
  • Harder to trace: Debugging callback chains can be tricky, especially when multiple layers are involved.
  • Runtime Overhead: If callbacks aren’t used, you still pay a performance penalty.
2. Virtual Methods
Usage: Core to polymorphism in SystemVerilog; allows base classes to define behavior that derived classes override.
  • Polymorphism: Enables dynamic behavior based on object type.
  • Extensibility: Easy to add new behaviors via subclassing.
:cross_mark: Cons:
  • Inheritance rigidity: Deep hierarchies can become hard to manage.
3. Decorator Pattern
Usage: Less common but achievable by wrapping objects and forwarding calls. Useful for layering functionality.
  • Behavior layering: Add features without modifying original class.
  • Avoids subclass explosion: Compose behaviors instead of creating many subclasses.
:cross_mark: Cons:
  • Complex object chains: Multiple decorators can make debugging harder.
  • Manual forwarding: You must explicitly forward all methods, which can be tedious.
Thanks for the response @dave_59,
The link to the “decorator pattern” seems to be broken..
I’ve corrected the error. I missed one character when copy&pasting.
