module
//strings
initial
for(int i=0;i<5;i++)
$display(“value of i=%3d”,i);//difference between %3d and %03d
In reply to tgs:
For your example there is no difference.
See the your code example slightly modified:
for(int i=0;i<105;i++)
$display("value of i = %3d :: i = %03d",i, i);//difference between %3d and %03d
But there is a difference in the following example:
$display("value of i = %h :: i = %0h",i, i);//difference between %3d and %03d
%0h is skipping all leading ‘0’.
In reply to tgs:
Hi just take out the fallowing snippet and note the result given for different scenarios.
integer i;//You can use any data type you want
initial
i=2456;//Some unsigned integer value assigned to variable i
$display("Value of i=%3d, i====%03d, i=%0d",i,i,i);
#10;
i=24;
result:
@time=0
Value of i= 2456, i====2456, i=2456
In the above result for first “i” variable “i=%3d” means the “i” value has to be print after 3 space character, second “i” variable “i====%03d” means zero(0) represents no white space character for displaying the “i” value and here 3 represents the value of “i” should be fitted in 3 character space only, that you can check in the @10 time unit delay result, and “i=%0d” means without any white space character the “i” values has to be printed.
Result:
"time=10
Value of i= 24, i====024, i=24
In reply to Sriram Yalavatti:
thank you bro
thank you sir
