What is the difference between below 2 codes?
a=0; b=1;
a = #3 1;
c = #5 a + b;
a=0; b=1;
#3 a = 1;
#5 c = a + b;
What is the difference between delay after the ‘=’ and before the variable name?
Thanks.
a=0; b=1;
a = #3 1;
c = #5 a + b;
a=0; b=1;
#3 a = 1;
#5 c = a + b;
Thanks.
two type of delay is there 1.regular delay 2. intra delay
regular delay we define like below
a=0; b=1;
#3 a = 1;
#5 c = a + b;
the meaning of this is at simulation time “0” a=0 and b=1
at simulation time “3” a=1
at simulation time “8” c=a+b
this above all you defined that regular delar.
intra delay we define like below
a=0; b=1;
#5; // modified your code here by me see this is the blocking right so in the blocking regular delay add with the intra delay so at simulation tim"5" a=0; b=1;
a = #3 1; // here at simulation time "8" at that time the value of the a=1;
c = #5 a + b; // 5+3+5+5=18 so at simulation time"18" c=a+b;
this below code add by me
a<=0; b<=1;//see this is the non blocking code so in this the intra delay is not add with the regular delay
#5; at "5" a=0 and b=1
a <= #3 1;
#5; at "10" a=1;
c <= #5 a + b;
In reply to jaswanth_b:
Any procedural statement can have a number of optional delay controls in front of it, as long as the procedural block is in a place that allows delays (i.e. you cannot have delays inside a procedural function)
a = 0;
#1 a = 1;
#2 #3 a =3;
#4 $display($time);
is the same as
a = 0;
#1;
a = 1;
#2;
#3;
a =3;
#4;
$display($time);
Using the ; here makes no difference, both display time as 10. But there are places where it matters whether there is one statement or multiple statements.
if (condition1)
#4 $display($time);
if (condition2)
#4; $display($time); // the $display is not part of the if statement.
The intra-assignment delay statement is left over from very early Verilog before non-blocking assignments were added to the language. They no longer should be used. Basically
A = #delay B;
is equivalent to
temp = B;
#delay
A = temp;
You ahould instead use
A <= Delay B;
which delays the assignment to A without blocking the flow of procedural statements.
Thank you both for answering.
