I want to define some text strings that I can send over a UART in my FPGA. If I were coding this in C, I’d be wanting something like this:
char Prompt1[] = "This is prompt 1";
char Prompt2[] = "This is prompt 2";
So what is the best way to do this in SystemVerilog? My code needs to be FPGA synthesizable.
All I want is a bunch of byte arrays but I don’t want to declare each byte as individual ASCII chars or hexadecimal values like this:
byte prompt1 [0:7]; = '{"a", "b", "c", "d", "e", "f", "g", "h"};
I can’t use packed arrays like this:
bit [0:87] BIT_ARRAY = "Hello world";
I need to use an unpacked byte array so I can access the individual bytes.
I’ve been able to do it as shown in the below link but this will be a very expensive way of doing it:
module Test( input logic reset );
typedef byte STRING[0:255];
byte promptId;
localparam byte PAGE1 = 1;
localparam byte PAGE2 = 2;
localparam byte PAGE3 = 3;
function STRING getStr();
int i;
string txPage1 = "Page 1";
string txPage2 = "Page 2";
string txPage3 = "Page 3";
STRING str = '{default:0}; // Initialise all elements with 0
if( promptId == PAGE1 )
for(i=0; i<txPage1.len(); i++)
str[i]=txPage1[i];
if( promptId == PAGE2 )
for(i=0; i<txPage2.len(); i++)
str[i]=txPage2[i];
if( promptId == PAGE3 )
for(i=0; i<txPage3.len(); i++)
str[i]=txPage3[i];
return str;
