In reply to kvssrohit: As I said before, macros get expanded as text for any generate processing. `dev_(i) gets expanded as top.i.XXX
The only way to achieve what you want withing SystemVerilog is to restructure your instance names into an array and access them with proper indexing. top[i].
Otherwise there are other macro processing tools that you can use to generate the identifier names you are looking for. But that becomes quite a maintenance headache.
