I am having a argument with someone on the use of deep copy. I was convinced by the other guy until i run my deep copy function and find it works.
Basically if I want to do a deep copy, say
class A
int c;
class B
A a
int i;
function new();
a = new();
i said to have a copy function inside Class B like this
function copy(A a);
this.a = new a;
B b1,b2;
initial
b1 = new();
b1.a.c = 1;
b1.i = 0;
b2 = new b1;
b2.copy(b1.a);
so he said this wouldn’t work because "this.a = new a " is copying the handle value passed from b1.a so this.a will still have the same memory location. And I sort of agreed because copy using new is shallow copy, but when I run my code, i found out the when i change “b1.a.c = 2;”, my b2.a.c would stay at 1 so it means it has a new memory location already. The other guy suggest me to write another copy function inside Class A to really do deep copy but i found without having that class also works as a deep copy.
Can someone kindly explain?
Besides, I do have another question regards writing a function to clone struct.
struct Node{
int a;
bit map[string];
Node nextNode;
How to clone the associative array is my main concern since i think it doesn’t take any memory location until it is used.
Any help is much appreciated!
