I m using QuestaSim 6.6b. I have a problem with using cross_auto_bin_max.
For instance, consider the following code:
CP_1: coverpoint a;
CP_2: coverpoint b;
CP_3: coverpoint c;
CP_4: coverpoint d;
cross_1: cross CP_1, CP_2, CP_3, CP_4
bins b1 = binsof (CP_1) && binsof(CP_2) && binsof(CP_3)intersect {1} &&
binsof(CP_4) intersect {0};
options.cross_auto_bins_max = 0;
From the above code, i expect that though there are 16 cross combinations (a,b,c,d are single bit values), the required number of combinations is of bin “b1” (4).
Therefore, by adding options.cross_auto_bins_max = 0, it is expected that other automatic bin combination should not be generated.
This does not seem to be happening in QuestaSim.
Is there a limitation in using this option?
