Hello
I want to create unique values in an array. I understand SV provides unique construct to do such a thing. However I want to constraint those array values further between 2 values.
class Nibbleset
rand bit [3:0] nibbles[10];
constraint uniq {unique {nibbles};}
Problem here is that values are constrained by size of each entry which is 4 bit. So each value can be between 0 and 15. if I want say unsized array or queue with randomized size and unique values between integer a and b, is there construct which comes with unique ?
rand logic [4:0] d_arr[$];
constraint uniq {d_arr.size < 7;
unique {d_array}}
Something in 2nd code to say please choose value between 7 and 30 ?
In reply to aashishs2603:
You can use a foreach iterative constraint and the inside operator to constrain each element in a range. You should also use inside constrain the size of the array.
constraint uniq {d_arr.size inside {[1:7]};
unique {d_arr}};
foreach (d_arr[i]) d_arr[i] inside {[7:30]};
Thanks Dave. I used foreach and it worked. However I was thinking since unique was introduced to remove foreach from constraint is there any other method without foreach?
Also there is construct which I tried which should exclude values but it did not work. I still values being included
const bit [4:0] excludes {0,1,2};
constraint uniq {d_arr.size inside {1:7};
unique {d_array,excludes}};
