Creating multiple objects for single instance of class
Code -
class a;
  int b;
module test();
  initial
    a a_inst;
    for (int i = 0; i < 10; i++)
      a_inst = new();
Question -
Since the loop executes 10 times, it will create 10 objects. But the same handle is pointing to different instances on each iteration.
What happens to all 9 objects at the end of the loop?
In reply to naveensv:
Actually, a_inst is a class variable, the handle is what gets stored in the variable. (See A Short Class on SystemVerilog Classes - Verification Horizons)
SystemVerilog does not let you know what happens to the other 9 objects—you no longer have handles to access them. The only thing SystemVerilog does is guarantee existence while a class variable holds a handle to an object.
