Creating an array of driver
Hi
I want to create an array of driver. The following are the codes. vsim shows Fatal error while running the simulation: Fatal: (SIGSEGV) Bad handle or reference. The Fatal error is pointing to the code with bold character.
class efm_env extends uvm_env;
   abc_drv abc_drv_ch[16];
   function new(string name="", uvm_component parent=null);
      super.new(name, parent);
      super.build_phase(phase);
      for (int i=0; i<16; i++) begin
         abc_drv_ch[i].cfg(i);
         abc_drv_ch[i] = abc_drv::type_id::create($sformatf("abc_drv_ch_%2d", i), this);
class abc_drv extends uvm_component;
   bit [3:0] chid;
   virtual abc_if v_abc_if;
      if (!uvm_config_db #(virtual abc_if )::get(
             this, "", $sformatf("drv_ch_%2d", chid), v_abc_if))
      `uvm_error("CONFIGURATION", $sformatf("Could not get virtual interface v_abc_if[%2d]", chid));
   function void cfg (bit [3:0] ch=0);
     **chid = ch;**  <---Fatal: (SIGSEGV) Bad handle or reference
Thank you for your help.
John
The problem is with this code…
abc_drv_ch[i] = abc_drv::type_id::create($sformatf(“abc_drv_ch_%2d”, i), this);
You are trying to access the driver method cfg before creating the object of the driver. First create the object of the driver and then access the method.
The below code should work…
In reply to malathi@aceic.com:
But the following code is in the build phase, which will use the value of chid[3:0] to retrieve the right interface.
             this, "", $sformatf("drv_ch_%2d", **chid**), v_abc_if))
If I put
after
, will it get the right interface in above code in build phase?
Thanks.
John
Well this will only fix the run time error problem but will not fix the design problem you are mentioning. One way to fix this would be to set the variable(chid) in config database(in efm_env) before creating the driver object and get this variable from the config database in the driver before getting the virtual interface. It is recommended to create a configuration object as described in the cookbook.
