how to create a folder in SystemVerilog?
In reply to Moein75:
There is no such thing as a “folder” in SystemVerilog. Please explain further.
I mean how to create folder through SystemVerilog code. For example we can create file using $fopen, can not we create folder?
There is no such funciton/task/macro to create folder, only you can use mkdir in you makefile.
On most operating systems, fopen only creates files and does not know anything about folders or directories. You have at least three options:
- create the folder using the script that invokes your simulation
- If you are running on Linux, you can import the mkdir system function, then call it.
import "DPI-C" function int mkdir(input string path, int mode);
- Use the $system(“mkdir myfolder” systemfunction.
