CRC generation post_randomize upon packing the bits
I am trying to create a base class transaction to pack the frame to transmit as serial data.I am unable to pack the CRC fileds after ranomization,and I seet that the dynamic array has data,but it does not get packed into bits,and CRC calculation is always displayed as 0,hene require help in seeking the right pointers for CRC,packed into frame for serial tx.
class can_transaction extends uvm_sequence_item;
  //parameterized data randomizationfor can txn type
  rand  bit  SOF ;
  rand  bit[10:0] can_identifier ;
  rand  bit  RTR ;
  rand  bit  IDE ;
        bit  R0  ; //reserved bit
  rand  bit [3:0]  DLC ;
  rand  bit [7:0]  data[] ;
        bit [15:0] CRC=16'h0000 ;
  rand  bit [1:0]  ACK ;
  rand  bit [6:0]  EOF ;
  rand  bit [6:0]  IFS ;
  //crc calulation
  bit crc_next ;
  logic [14:0] crc_reg=15'h0000 ;
  bit bit_frame[] ;
  int pkt_len,bit_frm_len;
  bit [7:0] data_byte[] ;
  bit pack_frame[];
    int count=0 ;
  bit[7:0] data_bit[];
  constraint priority_c {
                          solve DLC before data ;
  constraint DATA_Size_C {
                           data.size()==DLC;
  constraint DLC_C {
                     DLC inside {[8:8]};
  constraint identifier_c {
                           !(can_identifier[10:4]==7'b1111111);
                             can_identifier==4'b0111 ;
  constraint ACK_C {
                     ACK==2'b11 ;
  // UVM Factory Registration Macro
  //We will define packing and unpacking methods manually,
  //so use UVM_NOPACK for excluding atomic creation of packing
  //and un packing method.
    `uvm_object_utils_begin(can_transaction)
    `uvm_field_int(SOF, UVM_ALL_ON | UVM_NOPACK )
    `uvm_field_int(can_identifier, UVM_ALL_ON| UVM_NOPACK )
    `uvm_field_int(RTR, UVM_ALL_ON | UVM_NOPACK )
    `uvm_field_int(IDE, UVM_ALL_ON| UVM_NOPACK )
    `uvm_field_int(R0, UVM_ALL_ON| UVM_NOPACK )
    `uvm_field_int(DLC, UVM_ALL_ON | UVM_NOPACK )
    `uvm_field_array_int(data, UVM_ALL_ON | UVM_NOPACK )
    //`uvm_field_int(CRC, UVM_ALL_ON | UVM_NOPACK )
    //`uvm_field_int(ACK, UVM_ALL_ON | UVM_NOPACK )
    //`uvm_field_int(EOF, UVM_ALL_ON | UVM_NOPACK )
    //`uvm_field_int(IFS, UVM_ALL_ON | UVM_NOPACK )
  `uvm_object_utils_end
  // Standard UVM Methods:
  function new (string name="can_transaction");
    super.new(name);
  //print method
  virtual function void do_print(uvm_printer printer);
    super.do_print(printer);
    printer.print_field(.name("SOF"),
                        .value(SOF),
                        .size($bits(SOF)),
                        .radix(UVM_HEX));
    printer.print_field(.name("can_identifier"),
                        .value(can_identifier),
                        .size($bits(can_identifier)),
                        .radix(UVM_HEX));
    printer.print_field(.name("RTR"),
                        .value(RTR),
                        .size($bits(RTR)),
                        .radix(UVM_HEX));
    printer.print_field(.name("IDE"),
                        .value(IDE),
                        .size($bits(IDE)),
                        .radix(UVM_HEX));
    printer.print_field(.name("R0"),
                        .value(R0),
                        .size($bits(R0)),
                        .radix(UVM_HEX));
    printer.print_field(.name("DLC"),
                        .value(DLC),
                        .size($bits(DLC)),
                        .radix(UVM_HEX));
    foreach(data[i])
        printer.print_field(.name("data"),
                            .value(data[i]),
                            .size($bits(data[i])),
                            .radix(UVM_HEX));
    printer.print_field(.name("CRC"),
                        .value(CRC),
                        .size($bits(CRC)),
                        .radix(UVM_HEX));
   // printer.print_field(.name("ACK"),
   //                     .value(ACK),
   //                     .size($bits(ACK)),
   //                     .radix(UVM_HEX));
   // printer.print_field(.name("EOF"),
   //                     .value(EOF),
   //                     .size($bits(EOF)),
   // printer.print_field(.name("IFS"),
   //                     .value(IFS),
   //                     .size($bits(IFS)),
  virtual function void do_pack(uvm_packer packer);
    //super.do_pack(packer);
    packer.pack_field_int(SOF,$bits(SOF)          );
    packer.pack_field_int(can_identifier,$bits(can_identifier));
    packer.pack_field_int(RTR,$bits(RTR));
    packer.pack_field_int(IDE,$bits(IDE));
    packer.pack_field_int(R0,$bits(R0));
    packer.pack_field_int(DLC,$bits(DLC));
    foreach(data[i])
        packer.pack_field_int(data[i],$bits(data[i]));
    //packer.pack_field_int(CRC,$bits(CRC));
    //packer.pack_field_int(EOF,$bits(EOF));
    //packer.pack_field_int(IFS,$bits(IFS));
  virtual function void do_unpack(uvm_packer packer);
    //super.do_unpack(packer);
    SOF=packer.unpack_field_int($bits(SOF)          );
    can_identifier=packer.unpack_field_int($bits(can_identifier));
    RTR=packer.unpack_field_int($bits(RTR));
    IDE=packer.unpack_field_int($bits(IDE));
    R0=packer.unpack_field_int($bits(R0));
    DLC=packer.unpack_field_int($bits(DLC));
    data.delete();
    data=new[DLC];
    foreach(data[i])
      data[i]=packer.unpack_field_int($bits(data[i]));
    //CRC=packer.unpack_field_int($bits(CRC));
    //EOF=packer.unpack_field_int($bits(EOF));
    //IFS=packer.unpack_field_int($bits(IFS));
  virtual function bit [14:0] function_calc_can2_0_crc_15();
      pack(bit_frame);
     //bit_frame={<<{SOF,can_identifier,RTR,IDE,R0,DLC,data[0],data[1],data[2],data[3],data[4],data[5],data[6],data[7]}};
     `uvm_info("CAN CRC FUNC1",$sformatf("bit_frame_len=%0d  CRC value:%0h",$bits(bit_frame),CRC),UVM_LOW)
      foreach(bit_frame[i])
       count++ ;
          $display("count=%0d bit_frame[%0d]=%0d",count,i,bit_frame[i]);
        crc_next=(crc_reg[14]^bit_frame[i]);
        crc_reg[14:1]=crc_reg[13:0]; //left shift
        crc_reg[0]=0 ;
      if(crc_next)
        crc_reg[14:0]=(crc_reg[14:0]^15'h4599) ;
        CRC[15:0]={1'b1,crc_reg} ;
        `uvm_info("CAN PACKET TXN:CRC FUNC2",$sformatf("crc_reg=%0h, CRC value:%0h",crc_reg,CRC),UVM_LOW)
      return(CRC);
  endfunction : function_calc_can2_0_crc_15
	  uvm_table_printer uvm_default_table_printer=new();
	  this.do_print(uvm_default_table_printer);
endclass : can_transaction
In reply to RKCH:
I’m not getting the result you are. I added these 4 lines to make a complete reproducable testcase,
  can_transaction can = new("can");
  initial assert(can.randomize);
# UVM_INFO testbench.sv(188) @ 0: reporter@@can [CAN PACKET TXN:CRC FUNC2] crc_reg=4599, CRC value:c599
