Hi All,
I want to get the number of unique values in an array / a queue.
This method does not work
int values[$] = '{1,2,3,4,1,2,3,4};
int unique_value_count;
unique_value_count = values.unique().size();
It gives the following error message
Member operator “.” cannot be used on object of type int.
Expression: this.values.unique
Source info: values.\unique ().size
Following method works
int unique_values[$];
unique_values = values.unique();
unique_value_count = unique_values.size();
First implementation is more concise and I prefer it more than second one.
Could someone please help me to figure out why the first method does not work?
My full requirement is to constraint the number of unique values in a queue.
constraint values_c{
values.size() == 5;
values.unique().size() == 2;
Thanks in advance.
In reply to tharindu:
The first method is known as function chaining. This syntax was just added to the upcoming IEEE 1800-2023 SystemVerilog LRM. Some tools, like Questa, already support it. Check with your tool vendor.
Hi @dave_59,
Thank you very much for the information. I am using VCS 2023.03 version. I tested in EDA playground. Yes, the first method works well with Mentor Questa 2021.3. I will use the second method for the moment as VCS does’t support function chaining yet.
Thanks again!
I tried the followin code in Questa, i am getting constraint solver failure.
module tb();
class demo;
int values[];
values.size() == 5;
demo demo_h = new();
demo_h.randomize();
$display("values %0p",demo_h.values);
In reply to uvm_novice:
Hi @uvm_novice,
Yes, that’s true. It says that there are conflicts. But anyway Questa seems to support function chaining outside the constraints like below.
module tb();
class demo;
function void demo_f;
demo_h.demo_f;
$display("unique_value_count: %0d", demo_h.unique_value_count);
