return a array like
bit[7:0] marray[8][30];
in sv
return a array like
in sv
In reply to designer007:
Yes, but you need to declare the return type using a typedef. The function declaration syntax does no allow any return types more complicated than a simple identifier with optional packed dimension…
typedef bsix mem_type [0:3]; // array of four ‘bsix’ elements
mem_type ba [0:7]; // array of eight ‘mem_type’ elements
so ba is array of 8*4 ‘bsix’ elements?
SV function cannot return bare multidimensional array. You should typedef the array, then you can make use of it to return the array.
Please refer the below example for returning multidimensional array.
typedef bit[7:0]data1;
typedef data1 data2[4][6];
function data2 func();
bit[7:0]array[4][6];
array[1][2]=5; //randomly assigning some value
$display("array is %p",array);
return array;
$display("data2 is %p",func());
Result:-
array is '{'{'h0, 'h0, 'h0, 'h0, 'h0, 'h0}, '{'h0, 'h0, 'h5, 'h0, 'h0, 'h0}, '{'h0, 'h0, 'h0, 'h0, 'h0, 'h0}, '{'h0, 'h0, 'h0, 'h0, 'h0, 'h0}}
data2 is '{'{'h0, 'h0, 'h0, 'h0, 'h0, 'h0}, '{'h0, 'h0, 'h5, 'h0, 'h0, 'h0}, '{'h0, 'h0, 'h0, 'h0, 'h0, 'h0}, '{'h0, 'h0, 'h0, 'h0, 'h0, 'h0}}
Yes.
To summarize, a function can return any data type, but some complex data types require using a typedef.
