Hi All,
Is there any method to copy a single column of a 2D queue directly to another queue?
something like the following (which didnt work):
dbg_base transq[:31][:3];
dbg_base transq_r1c1[$:31];
transq_r1c1 = {transq[0:$][0]};
Hi All,
In reply to abisha:
Hi Abisha,
You can not have a 2D queue, but you can take array of queue and then copy single column as required.
In reply to Parth4448:
Consider changing the dimension ordering.
dbg_base transq[$:3][$:31];
transq_r1c1 = transq[0]};
Otherwise you would have to use a foreach loop.
Thanks for your reply Dave.
Unfortunately , i cant change the dimensions. I am using a foreach loop for now.
