While going through UVM Cookbook I observe the following code ::
`include "uvm_pkg.sv"
`include "uvm_macros.svh"
import uvm_pkg::*;
class my_bus_config extends uvm_object ;
// Factory Registration and Std 3 line Object Constructor
bit [4:0] enable_error_injection ;
class my_bus_seq extends uvm_sequence ;
string scope_name = "";
task body();
my_bus_config m_config;
if( scope_name == "" ) begin
scope_name = get_full_name(); // this is { sequencer.get_full_name() , get_name() }
`uvm_info( get_name(),$sformatf(" scope_name is %0s ",scope_name),UVM_NONE )
if( !uvm_config_db #( my_bus_config )::get( null , scope_name , "my_bus_config" , m_config ) )
`uvm_error(get_name(),$sformatf(" Unable to Fetch ") )
else begin
`uvm_info( get_name(),$sformatf(" m_config.enable_error_injection is %0d ",m_config.enable_error_injection ),UVM_NONE )
class my_agent extends uvm_agent ;
typedef uvm_sequencer seqr ;
seqr seqr_h ;
// Factory Registration and Std 3 line Component Constructor
function void build_phase ( uvm_phase phase ) ;
seqr_h = seqr::type_id::create("seqr_h",this) ;
class my_env extends uvm_env ;
my_agent agent1 ;
my_bus_config agent1_config , agent1_error_config ;
agent1 = my_agent::type_id::create("agent1",this) ;
agent1_config = my_bus_config::type_id::create("agent1_config") ;
agent1_config.enable_error_injection = 0 ;
agent1_error_config = my_bus_config::type_id::create("agent1_error_config") ;
agent1_error_config.enable_error_injection = 10 ;
`ifdef M1 // Reverse Order of set of Cookbook
// sequences with "error" in their name will enable error injection
uvm_config_db #( my_bus_config )::set( this , "agent1.seqr_h.error*" , "my_bus_config" , agent1_error_config ); // [A1]
// most sequences do not enable error injection
uvm_config_db #( my_bus_config )::set( this , "agent1*" , "my_bus_config" , agent1_config ); // [B1]
`else // Same Order of set as Cookbook
uvm_config_db #( my_bus_config )::set( this , "agent1*" , "my_bus_config" , agent1_config ); // [A2]
uvm_config_db #( my_bus_config )::set( this , "agent1.seqr_h.error*" , "my_bus_config" , agent1_error_config ); // [B2]
`endif
task main_phase( uvm_phase phase ) ;
my_bus_seq normal_seq = my_bus_seq::type_id::create("normal_seq");
my_bus_seq error_seq = my_bus_seq::type_id::create("error_seq");
phase.raise_objection( this ) ;
normal_seq.start( agent1.seqr_h ) ;
error_seq.start( agent1.seqr_h ) ;
join
phase.drop_objection( this ) ;
module Cookbook_Configuring_Per_Sequence_Configuration ;
initial run_test("my_env" ) ;
Without any define I Observe ::
UVM_INFO @ 0: reporter [RNTST] Running test my_env…
UVM_INFO @ 0: uvm_test_top.agent1.seqr_h@@normal_seq [normal_seq] scope_name is uvm_test_top.agent1.seqr_h.normal_seq
UVM_INFO @ 0: uvm_test_top.agent1.seqr_h@@normal_seq [normal_seq] m_config.enable_error_injection is 0
UVM_INFO @ 0: uvm_test_top.agent1.seqr_h@@error_seq [error_seq] scope_name is uvm_test_top.agent1.seqr_h.error_seq
UVM_INFO @ 0: uvm_test_top.agent1.seqr_h@@error_seq [error_seq] m_config.enable_error_injection is 10
[Q1] How is the sequence able to fetch the appropriate configuration ? How do statements [A2] and [B2] impact the get Calls ?
With [A2] argument ‘inst_name’ “agent1*” covers “agent1.seqr_h.error*” right ?
With +define+M1 I Observe ::
UVM_INFO @ 0: uvm_test_top.agent1.seqr_h@@error_seq [error_seq] m_config.enable_error_injection is 0
[Q2] Why does the Output differ in this case ? How do statements [A1] and [B1] impact the get Calls ?
