We have a SV module that I need to port over to OVM. What is a good resource for that? The module basically takes two interfaces and copies data from one to the other based on a config.
I assume you wanted to ask how to use an exiting module as a bus-functional model called from an OVM driver. See OVM wrapper for Verilog Bfms?? | Verification Academy
In reply to jdubrow:
Can you please elaborate your question?
Problem is solved, sort of. I found a way to keep it as a module in our env.
Can you please help me to know something about the OVM module?
What type of module it is and what are its hardware specifications?
Also what are its applications and how it will be helpful in electronics hardware designing?
Can you please post some examples related with it?
