I am struggling to understand, how to control the fork join_none threads launched as below:
while (outer loop) begin
thread-x;
thread-outer-1;
thread-outer-2;
thread-outer-3;
join_none
while (inner loop) begin
thread-inner-1;
thread-inner-2;
thread-inner-3;
join_none
wait fork;
Here, I would like to wait for ONLY the thread-inner- to complete for the duration of the inner loop. Having wait fork, (I believe) waits for the thread-outer- also to complete, which is not what I want.
How can I “wait” only for the threads in the inner loop to finish, and then wait for the threads in the outer loop to finish before I start the next iteration of the outer loop?
Madhu
In reply to mseyunni:
In my opinion, the definition of the problem is insufficient. What is:
1.) duration of the inner loop?
2.) Do you intend to terminate the inner loops at the end of some duration? Or will they run to completion?
3.) In your last sentence you stated that you wanted to wait for the first iteration of the outer loop to complete before beginning the next iteration. If that is what you want, why do you need an inner and outer loop at all? Just fork the outer and inner loops off with a fork/join.
Ignoring my confusion…I would simply state that if you use fork/join instead of fork/join_none on the inner loops, then move the wait fork so that it executes after completion of the inner loop, that may be a solution, to a problem I don’t fully understand :)
Just use a fork/join instead of fork/join_none/wait fork in the inner loop.
thread-x;
thread-outer-1;
thread-outer-2;
thread-outer-3;
join_none
while (inner loop)
thread-inner-1;
thread-inner-2;
thread-inner-3;
join
wait fork;
Thank you Dave and dhserfer for answers. Yes. It works for my requirement. However, Can we use wait fork to control only one loop if there was such a requirement?
Madhu
You can, but I don’t think the way you want to do it is much harder to follow
thread-x;
thread-outer-1;
thread-outer-2;
thread-outer-3;
join_none
while (inner loop)
fork begin
thread-inner-1;
thread-inner-2;
thread-inner-3;
join_none
wait fork;
end join
wait fork;
